How to make a properties box
During some more research on what I am trying to accomplish, I found information about batch tables that are assigned to the features. I was wondering if you could potentially help explain these. Is there a batch table assigned to each 3D tileset when it is added to the Cesium Ion? Can I edit this information? How can I get it to display and edit it if so?
Claire
@CSettle2021
I am happy to hear that the sandcastle demo that I provided was helpful! As you know, creating sandcastle demos takes some time so I appreciate your patience.
Off the top of my head, I can’t think of a quick and easy way to show the same results given from selecting a Billboard when selecting an uploaded model. This would be a great place for other community members to add some suggestions!
It is possible to scale the billboard! If you look over the Billboard documentation that I referenced in my last response, you will see that Billboard has the member scaleByDistance, which allows you to set the scaling properties of a Billboard based on its distance from the Camera. Here is an example of how to use scaleByDistance:
// Example 1.
// Set a billboard's scaleByDistance to scale by 1.5 when the
// camera is 1500 meters from the billboard and disappear as
// the camera distance approaches 8.0e6 meters.
b.scaleByDistance = new Cesium.NearFarScalar(1.5e2, 1.5, 8.0e6, 0.0);
It seems like your questions about 3D Tiles are posted in two different threads. I answered your questions in the other thread, which I will add here for continuity.
Let me know if you have any other questions or concerns!
Sam
Hi @sam.rothstein ,
So I have found a bit of a work around solution for what I am trying to accomplish. Here is my solution which includes using a CZML box over the building that is transparent to show the properties on the side.
I still had a couple of questions I was hoping you could help with. As you can see in the example, I am trying to have a drop down sorting by phases 1 and 2 or show both. These phases will be color with 1 being yellow orange and 2 being blue. When one is selected, I want only those that are yellow orange to be shown and vise versa. Is there any way of assigning something to this tileset to be able to do so? I know typically I would use code like:
function highlightAllResidentialBuildings() {
osmBuildingsTileset.style = new Cesium.Cesium3DTileStyle({
color: {
conditions: [
ā€œ${feature[ā€˜building’]} === ā€˜apartments’ || ${feature[ā€˜building’]} === ā€˜residentialā€™ā€,
ā€œcolor(ā€˜cyan’, 0.9)ā€,
[true, ā€œcolor(ā€˜white’)ā€],
But since these properties do not exist, I do not know how to go about this. Additionally, I was wondering how to do the same thing with other properties assigned to the types 1-6. My other questions were, do you know how I could add an image to the properties box? I was attempting to do this under the website link.
Claire
Hello, have you solved your initial problem?
Upload an FBX file to the ion platform, display the model in CesiumJS, and click the model to display the infobox of the area.
I also have such a problem, how to assign metadata to the model.
I guess @CSettle2021 wants to achieve: click on a certain area of ​​the model to display the metadata information of that area.
But there is a problem. When uploading FBX file to ion platform, the metadata of the file will be lost.
Hello, i am currently facing a similar issue that when i upload fbx file on cesium ion the metadata gets lost in the conversion. Is there a solution to how i can not just load fbx model but also be able to retain metadata and show it using click in an infobox?
Hi @Umar_Yaseen, could you please open a new thread in the Cesium ion category? The tiling of the fbx model is handled by ion rather than CesiumJS.
Thanks!
