How to make polylines always visible
Im drawing a polyline and it’s not visible through building or terrain, is there a way to force it to always show no matter what?
I’ve seen it in one of cesium measure example but I cannot tell which property is responsible for that
working version can be seen here: Cesium Stories
this is what I currently have:
measure
Hi @Nitsan_Baleli,
you have to declare the “depthFailMaterial” for the polylines like in this code snippet:
        polyline: {
            positions: [Cesium.Cartesian3.fromDegrees(point1.lon, point1.lat, point1.height), Cesium.Cartesian3.fromDegrees(point2.lon, point2.lat, point2.height)],
            width: 2.0,
			material: Cesium.Color.CHARTREUSE,
            depthFailMaterial: Cesium.Color.CHARTREUSE
Best, Lennart
Hi @lennart.imberg , I didn’t mention it but Im already using it.
if you could look at the gif in the original post, it seems that depthFailMaterial only comes into play after the second click ?
this is the relevant code of how the polyline is made:
var dynamicPositions = new Cesium.CallbackProperty(function () {
  return activeShapePoints;
}, false);
polyline: {
  positions: dynamicPositions,
  width: 3,
  material: new Cesium.ColorMaterialProperty(
    Cesium.Color.RED.withAlpha(0.7)
  depthFailMaterial: Cesium.Color.RED.withAlpha(0.7),
  heightReference: Cesium.HeightReference.RELATIVE_TO_GROUND,
it may be related to this: depthFailMaterial for dynamic polylines · Issue #5333 · CesiumGS/cesium · GitHub
Here’s one of my config setups for these lines (where props is a plain key-value object);
polyline: {
                    positions: props.positions,
                    width: props.lineWidth,
                    arcType:   Cesium.ArcType.GEODESIC,
                    perPositionHeight: props.perPositionHeight,
                    classificationType: Cesium.ClassificationType.BOTH,
                    clampToGround : props.clampToGround,
                    material: new Cesium.PolylineOutlineMaterialProperty({
                        color: props.color,
                        outlineColor: Cesium.Color.LIGHTGREY.withAlpha(0.4),
                        outlineWidth:0
                    depthFailMaterial: new Cesium.PolylineOutlineMaterialProperty({
                        color: Cesium.Color.LIGHTGREY.withAlpha(0.4),
                        outlineWidth:0
You might have better luck with a polyline material for this purpose rather than a plain color, I’m not sure why but I never got those working well (or consistent).
Cheers,
Alex
