polyline is not transparent while drawing on terrain loaded globe.
Hi sir, I am trying to draw the polyline using the mouse handlers over the terrain loaded globe. While drawing the polyline the line is going under the terrain and sometimes not visible. Once i completed the drawing it is becoming transparent. How to make the line transparent while drawing also.
shape = viewer.entities.add({
polyline : {
positions : positionData,
width : 3,
material : new Cesium.PolylineOutlineMaterialProperty({
color : Cesium.Color.YELLOW.withAlpha(0.7)
depthFailMaterial : new Cesium.PolylineOutlineMaterialProperty({
To mark the areas
Any solution for this for making polyline transparent and visible.
Can you post a full Sandcastle example I can run? Are you saying the polyline appears with the correct color only when it is static? Are you using a CallbackProperty to make it dynamic while drawing?
A picture might also help.
