Hi @woaiman1022,
What is your end goal here? You still want all of the labels to show but not to blend?
My suggestion will depend on your answer to that, but here a few things to consider in the meantime:
- distanceDisplayCondition - you can control at what distance certain billboards will show.
- There’s a bug introduced in Cesium 1.135 that creates bad interactions between overlapping labels / billboards. It should be fixed in the next release (next week) with this PR. You could try your app with either 1.134 or 1.136, when it releases, to see if your issue is solved.
Matt
I think you can use PinBuilder.
Please check this.
What I want to achieve is to zoom in and out of the map, that is, if the labels overlap, they will be hidden until they can be fully displayed, and then displayed again
