How to optimize the problem of stuttering when loading multiple GLB models in cesiumjs
My computer is configured with i9-12900KS RTX3080TI 96GB
GPU is basically 80% -100%
When I rotate and move, it feels very laggy
const loadModel = async (glb: any) => {
return new Promise(async (resolve) => {
console.log(glb, " 加载单个 GLB 模型");
const hpr = new HeadingPitchRoll(heading, pitch, roll); // 初始姿态
// 如果你想让模型从当前方向向右转 45 度
let rotationAngleInDegrees = 121;
let rotationAngleInRadians = CesiumMath.toRadians(rotationAngleInDegrees);
// 更新 heading
hpr.heading = (hpr.heading + rotationAngleInRadians) % (2 * Math.PI);
// Heading (朝北角度,偏航)
// Pitch (上下倾斜角度,俯仰)
// Roll (水平旋转角度,翻滚)
const modelMatrix = Transforms.headingPitchRollToFixedFrame(
  position,
  hpr,
  Ellipsoid.WGS84
// 保存初始矩阵供后续使用
const initialModelMatrix = modelMatrix.clone();
const model = await Model.fromGltfAsync({
  url: glb,
  modelMatrix: modelMatrix,
  scale: 0.01,
  // minimumPixelSize: 128,
  // maximumScale: Number.MAX_VALUE,
  incrementallyLoadTextures: true,
  // debugShowBoundingVolume: true,
  // outlineColor: Color.RED,
  // silhouetteSize: 2.0,
model.show = true;
modelRef.instance = model; // 引用保存,方便后续修改
modelRef.initialMatrix = initialModelMatrix; // 存储基准矩阵
modelRef.instance.color = getColor("White", opacity.value); // 设置模型透明度 "White", "Red", "Green", "Blue", "Yellow", "Gray"
// 通过轮询检查模型是否加载完成
const checkModelReady = setInterval(() => {
  console.log(model.ready);
  if (model.ready) {
    console.log("模型加载完成", checkModelReady);
    clearInterval(checkModelReady); // 停止轮询
  } else {
    console.log("模型正在加载...");
}, 100); // 每100毫秒检查一次模型加载状态
resolve(model);
for (const path of absolutePaths) {
if (!modelsMap.has(path)) {
const model = await loadModel(path);
modelsMap.set(path, model); // 存储模型引用
scene.value.primitives.add(model);
fps
Hi @Lancer-110, which version of CesiumJS are you using? We recently shipped some fixes to memeory usage when loading many models.
Hello, 1.124.0
现在有个新的问题. 我在加载一个整体超过13GB的3Dtiles的倾斜模型出现一直不停的加载.1.125.0
录屏_20250124_150246
