How to position a 3D model plane in Cesium
I’m new to Cesium. I’ve been tryint to follow this Build a Flight Tracker tutorial:
However, the example plane model does not appear to be available in Sketchfab.
This link from the tutorial does not work:
https://s3.amazonaws.com/cesiumjs/downloads/Cesium_Air.glb
So then I downloaded a different model plane from Sketchfab.
However, my model needs to be rotated 90 degrees clockwise.
Can you tell me how to do this?
My code is here as copied from the tutorial and updated with my own asset id:
// STEP 6 CODE (airplane entity)
    async function loadModel() {
      // Load the glTF model from Cesium ion.
      const airplaneUri = await Cesium.IonResource.fromAssetId(my_asset_id);
      const airplaneEntity = viewer.entities.add({
        availability: new Cesium.TimeIntervalCollection([ new Cesium.TimeInterval({ start: start, stop: stop }) ]),
        position: positionProperty,
        // Attach the 3D model instead of the green point.
        model: { uri: airplaneUri },
        // Automatically compute the orientation from the position.
        orientation: new Cesium.VelocityOrientationProperty(positionProperty),
        path: new Cesium.PathGraphics({ width: 3 })
      viewer.trackedEntity = airplaneEntity;
    loadModel();
My plane looks like this:
Thank you!
Thank you for letting us know about the broken link. I have opened an issue for our team to correct that.
Until then, you can also download the model from https://sandcastle.cesium.com/SampleData/models/CesiumAir/Cesium_Air.glb
Regarding the main issue:
Preferably, that glTF model should have the right orientation to begin with. There are some strict requirements in the glTF specification, and it looks like this model does not follow these conventions. If you have a chance, you could try to load the model in an editing application, rotate it properly, and save the result, so that it can be used in your application.
However, more generally: It is possible to create a Property that uses another Property as some sort of “delegate”, and performs additional computations on the result. Here is an example, which is just the final code from the tutorial, with two changes:
  • The model is replaced with the Cesium_Air.glb (as this is part of the sandcastle anyhow)
  • Two places that are marked with Forum 35349 that show how the model can be rotated by 90 degrees around the z-axis
Of course, this looks kinda wrong with the Cesium_Air.glb model:
Cesium Rotated Model
:slight_smile:
But sometimes, two wrongs make a right, meaning that it should be right for the model that has the wrong orientation. (You might have to rotate it by minus 90 degrees or so, but that’s a detail).
https://sandcastle.cesium.com/index.html#c=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
Thanks for your help, my plane is facing the correct way now :smiley:
Hi, @Jody-6! I’m glad you got another asset to work. We’ve also fixed the link to the airplane model in the tutorial.
