I am unable to find a way to prevent the camera from tilting or rotating when using the map in the ‘globe’ view. When viewing a flat map there is no problem, but using the flat map is not an option for my application.
I’ve attempted to constrain the axis using :
camera.constrainedAxis = Cesium.Cartesian3.UNIT_Z;
but there is no disernable change.
I’ve also attempted to set defaultLookAmount and defaultRotateAmount to 0 and that has no impact on behaviour of the camera.
The look and rotate are unnessesary for my application, and make navigating/zooming on mobile nearly impossible. The globe constantly turns and tilts, often resulting in a misconfigured map that needs to be refreshed to return to home.
Currently using 1.6, Kubuntu and Firefox, but this issue is common to all major OS and browsers.
