Want the transparent object in front not to be affected by the transparent object behind
Hi @Shunrai1,
Would you mind providing a minimal Sandcastle example that reproduces your use case?
Depending on the exact result you are looking for, this may have to do with the fact that CesiumJS uses order-independent translucency by default.
Gabby
The URL from the screenshot works in principle:
https://bagnell.github.io/cesium/Apps/Sandcastle/gallery/OIT.html
(The globe itself won’t show, and it’s using an old version of Cesium, so it may not be soooo heplful, but maybe you’ll find what you’re looking for…)
