I want to add a text like polygon on the ground, it should fit the ground, is this possible? cesium’s label makes me look at it from every angle it’s a frontal view, which is not what I need
You can convert text to image by using writeTextToCanvas and set it as material on either rectangle, box, plane or polygon. It’s not the best one, But you can play with by setting it’s font style. Here is the example.
- Regards
thanks @Jacky this is great
