The aim is to save the longitude, altitude and height information for each pixel in any camera view. A highly similar method can be found in https://github.com/CesiumGS/cesium/issues/4368.
quick SandCastle testbed (shared by another enthusiastic Cesium user). This code allows to obtain 3D coordinate for the pixel which the mouse points to. I was wondering if there is any way to save such pixel-wise 3D coordinate for all the pixels in the image.
We are doing a camera localization project, which requires labelled images to construct 2D-3D correspondence. (x,y pixel <—> longtitude, altitude, height coordinates)
To combine this feature in our feature rendering code, we would use the latest Cesium version I suppose. At this moment, we have digital terrain models + high-quality ortho-photos.
You can programmatically call pickPosition on any location, not just the mouse position. So you could get your polygon coordinates in world space, and then iterate over that space at some granularity and obtain all those positions.
This sounds like a cool project - will it be publicly available?
Thanks so much for your message. I had another question about the following code to generate the coordinates automatically:
var stringCart = "[";
for(var ii=0;ii<viewer.canvas.width;ii++){
for(var jj=0;jj<viewer.canvas.height;jj++){
var cur_pos = new Cesium.Cartesian2(ii, jj);
var ppCartesian = viewer.scene.pickPosition(cur_pos);
var ppCartographic = Cesium.Cartographic.fromCartesian(ppCartesian);
var s = Cesium.Math.toDegrees(ppCartographic.latitude).toFixed(4);
stringCart += “(” + s.toString() + “,”;
s = Cesium.Math.toDegrees(ppCartographic.longitude).toFixed(4);
stringCart += s.toString() + “,”;
s = ppCartographic.height.toFixed(0);
stringCart += s.toString() + “),”;
stringCart += “,test,”
stringCart += “]”;
downloadText(stringCart, “Coor.txt”);
It doesn’t work and in my test the problem is related to “Cesium.Cartographic.fromCartesian”. I checked the documentation and still could not solve the problem. BTW, Cesium 1.63 is used at the moment.
We are still working on this project and once we have some nice results, the proejct would be made public I suppose.
