I’m trying to show the billboard for the 3D models which I’ve loaded in the cesium. It is working fine. But, I’m having 3D models on stack. So the the billboard is getting inside the other model.
I try to set some height using eyeOffset. Now the billboard is in some height. I want to mark the model with billboard (i.e. I’ll load the model and the billboard in the same geo-coordinate).
I got this demo, if you view the billboard it will be in some height with the line mark from the ground.
Can any help help me, how to achieve that in my case. Appreciate if you could try it in the sandcastle example and provide the snippet.
You can set the Billboard’s ‘eyeOffset’ to closer Z, however it might clip the model. If it looks bad, maybe you can shift the billboard relative to the center, but in screen coordinates - using ‘pixelOffset’ on the billboard.
position : position,
orientation : orientation,
model : {
billboard : {
image : ‘YOUR IMAGE’,
eyeOffset : new Cesium.Cartesian3(0.0,0.0,-100.0), // Negative Z will make it closer to the camera
pixelOffset : new Cesium.Cartesian2(0.0,-32.0) // Optional offset in pixels relative to center
Notice that the pins used in the examples are created by the PinBuilder, you can set the ‘image’ of the billboard to the PinBuilder’s
Thank you for your post. It is working fine. I’m trying to achieve little user friendly popup which is similar to this video. The sample screenshot below.
Having line reference to the model. Any suggestions or clue to achieve this.
As you said, I could able to draw a poly-line from ground to the some position. But with angle. I’m not sure, how far SVG will help me draw a line from the corner.
If there is any better solution for this. Please do let me know.
Sorry if I have confused you a little, the remark about SVG was about the billboard’s image, not it’s relationship with the entity. It is meant to draw the billboard item but not the line connecting to center.
I could able to render 2D canvas. But I wanted to change the content dynamically. similar to this demo. The speed is dynamically changing on the marker or billboard. How it is working? Any idea!
If moving stuff and changing properties dynamically over time is what you are looking for, then that’s pretty easy with cesium!
Almost each property you assign to an entity can be dynamic - instead of assigning a position or color, for example, you can set them as
SampledProperty in which you define the keyframes of time and value, and Cesium will interpolate the value in each frame for you.
As you mentioned, I can change the position or color dynamically using the mentioned APIs. But I want to change the billboard data. I posted it in separate thread. Let me know you comment on the thread.
