I’m trying to load the billboard in top of the 3D model(gltf). But it is not rendering as expected. If the verticalOrigin is set to BOTTOM. The billboard is snapping with the model. If I change to TOP. The billboard position is changing with respect to the camera view.
Find the sandcastle code below.
var pinBuilder = new Cesium.PinBuilder();
function createModel1(url, lat, long, height, billboard) {
var position = Cesium.Cartesian3.fromDegrees(lat, long, height);
var billboardPosition = Cesium.Cartesian3.fromDegrees(lat, long, height + 10);
var heading = Cesium.Math.toRadians(135);
var pitch = 0;
var roll = 0;
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, heading, pitch, roll);
name : “Cesium Milk Truck”,
position : position,
orientation : orientation,
model : {
uri : url,
minimumPixelSize : 0
billboard: {
image: billboard,
show: true,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
position: billboardPosition
function createModel2(url, lat, long, height, billboard) {
var pitch = 0;
var roll = 0;
model : {
uri : url,
billboard: {
image: billboard,
show: true,
verticalOrigin: Cesium.VerticalOrigin.TOP
var cesium_milk_truck = pinBuilder.fromText(“Cesium Milk Truck”, Cesium.Color.WHITE, 50).toDataURL();
createModel1(’…/…/SampleData/models/CesiumMilkTruck/CesiumMilkTruck.bgltf’,-123.0744619, 44.0503706, 0, cesium_milk_truck);
var cesium_ground_billboard = pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 48).toDataURL();
createModel2(’…/…/SampleData/models/CesiumGround/Cesium_Ground.bgltf’, -123.0745619, 44.0503906, 0, cesium_ground_billboard);
var billboardPosition1 = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0504106, 5);
var position1 = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0504106);
name : ‘Blank blue pin’,
position: billboardPosition1,
billboard : {
image : pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 48).toDataURL(),
verticalOrigin : Cesium.VerticalOrigin.TOP
polyline: {
positions: [position1, billboardPosition1],
width: 1,
followSurface: false,
show: true,
verticalOrigin: Cesium.VerticalOrigin.TOP,
horizontalOrigin: Cesium.HorizontalOrigin.CENTER,
material: Cesium.Color.ROYALBLUE,
eyeOffset: new Cesium.Cartesian3(0.0, 0.0, -10.0), // Negative Z will make it closer to the camera
pixelOffset: new Cesium.Cartesian2(0.0, -150.0) // Optional offset in pixels relative to center
Also, billboard is having a properties called “position”. When I try to set the value to that. It is not working. I suppose to load the billboard in top of the polyline. If I give the position on entity level it is working. i.e. taking model position as entity position.
billboard : {
verticalOrigin : Cesium.VerticalOrigin.TOP,
polyline: {
width: 1,
show: true,
In the sandcastle example, the Cesium Ground model billboard is not snapping with the model. Also trying to load the billboard in top of the model.
Is’t possible to load the billboard in top of the model or in top of the polyline?
Thanks in advance!
