Is there a way to make sure a billboard is always on top of other billboards?
Something like the “raise” in primtiveCollection?
Try setting the z value of the eyeOffset.
Patrick
Thanks.
It doesn't work for me (at least I can't see any change...).
http://jsfiddle.net/yonatankra/jvjfkq9t/8/
Any idea why?
Reaching into the primitive like that won’t work because that primitive is managed by the DataSource and any changes you make under the hood may/will be overwritten.
The correct way to do it is modify the entity itself, I’ve updated your fiddle with a working version: http://jsfiddle.net/7npv52r6/
Starting with 1.6, you won’t need to use Cesium.ConstantProperty and will be able to assign directly.
Thanks.
Works great!
