I’m writing an app using CesiumJS that are used by non-powered gliders (e.g. paragliders). When standing on a mountain, I’d like to know what places I can reach with my current glide angle. I’m showing this to the user by displaying a half-transparent cone (a cylinder with zero width at the top) with a specific angle. The user then can work out where to land or if a specific landing field can be reached. This works without problems so far.
Now I want to take wind speed and direction of the overall wind into account. My first though would be to rotate the cone around the top tip, but for steeper angles it shows that this is the wrong approach. I think it’s more correct when I transform the cone and shear it in the wind direction: http://www.euclideanspace.com/maths/geometry/affine/index.htm#shear
The page shows how to construct the matrix, but I can’t find a way to apply it to an entity. See my current code below.
My current code looks like this:
I add a cylinder entity. In the lines you can see my previous approach, specifying a quaternion as orientation to rotate the cone. I’d like to shear the cylinder, though.
See my explanation in 1.
Currently using CesiumJS 1.66.
Thanks!
