Hello, as far as I can understand the polylines NOT clamped to terrain (clampToGround : false) are always looking to the camera with the same width:
I mean that rotating the camera around the polyline this one keep the same width regardless of the view angle
(in this Sandcastle example you can better understand what I mean https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=CZML%20Polyline.html&label=All)
But, when the polyline is clamped to terrain (clampToGround : true) this one does not keep anymore the same width, but it’s more like a “ribbon” on the terrain.
(in this Sandcastle example you can better understand what I mean https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Clamp%20to%20Terrain.html&label=All)
Is there a way to clamp the polyline to the terrain and at the same time keep its width constant regardless of the view angle?
Thank-you
viewer.entities.add({
polyline : {
positions : Cesium.Cartesian3.fromDegreesArray([
86.953793, 27.928257,
86.953793, 27.988257,
86.896497, 27.988257
clampToGround : true,
width : 5,
material : new Cesium.PolylineOutlineMaterialProperty({
color : Cesium.Color.ORANGE,
outlineWidth : 2,
outlineColor : Cesium.Color.BLACK
I’m doing a route web app with 3d maps, many routes are over the mountains so I need the terrain 3D model,
and I need to clamp my routes to the terrain.
At the same time my routes should be well visible regardless of the view angle
1.60
Chrome - Safari
