How to swap imagery providers on error
hi all,
Is there an easy way to swap my imagery provider for a different imagery provider if the first throws an error?
E.G.: My map loads with imagery from Bing; if for whatever reason it can’t access imagery from Bing (I typed in my key wrong, whatever), I’d like it to access imagery from a USGS server.
You can use the imageryProvider’s readyPromise to listen for whether it was successfully created, and if not, you can remove it and add a different layer. Luckily there is one failing Bing layer in Sandcastle we can use to test:
var imageryProvider = new Cesium.BingMapsImageryProvider({
url : ‘https://dev.virtualearth.net’,
mapStyle : Cesium.BingMapsStyle.ROAD
imageryProvider: imageryProvider
imageryProvider.readyPromise.then(function() {
console.log(“Success!”);
.otherwise(function(error) {
console.log(error);
// Remove the first layer:
viewer.imageryLayers.remove(viewer.imageryLayers.get(0))
// Add a different one:
viewer.imageryLayers.addImageryProvider(new Cesium.IonImageryProvider({ assetId: 3845 }));
Live Sandcastle link.
Thanks Omar, you’re a lifesaver.
