function processPbrMaterials(gltf, options) {
options = defaultValue(options, {});
// No need to create new techniques if they already exist,
// the shader should handle these values
if (hasExtension(gltf, 'KHR_techniques_webgl')) {
return gltf;
If I commented out the if judgment here, the model rendered black, and I tried to modify other judgments, but it was unsuccessful. I also tried to modify the b3dm file. I really don't know how to do it. I hope you can show me how to do it. Thank you very much.
I implemented model flattening by modifying the source code, but when b3dm had its own shader, the shader code I added did not work
1.57
