All the unzipped files downloaded from cesium.js should be uploaded to such website or can be linked from cesium.js ?
Cesium looks beautifully, but imaginery resolution is significantly weaker than in Google Earth.
Take a look at this getting started example: http://cesiumjs.org/tutorials/cesium-up-and-running/
It shows you how to run a local server to run a Cesium application.
Cesium has support for a number of different types of imagery providers. We default to Bing imagery, but you can switch that out for a different source. You can see the types of imagery providers we support here: http://cesiumjs.org/Cesium/Build/Documentation/ImageryProvider.html
Hannah
Thank you for your answer. I have found that earlier. It says, that downloaded and extracted content of the Cesium zip file should be copied
into a directory on server (?). But these files occupy a lot of space and uploading them would take a lot of time. Is it really necessary ?
You will just need to copy everything in the Build/Cesium folder. This includes the Assets, ThirdParty, Widgets and Workers directories and the Cesium.js file.
-Hannah
There are also referrers to;
Apps/Sandcastle/Sandcastle-header.js
Apps/Sandcastle/templates/bucket.css
Apps/Sandcastle/templates/bucket-requirejs.html
ThirdParty/requirejs-2.1.20/require.js
Apps/SampleData/kml/facilities/GroundStation.png
Pins are here:
Source/Assets/Textures/maki
Is it allowed to create a map based on Sandcastle demos ?
