The graphData field here will update to render different boxes on the Cesium map. Which works perfectly until I want to edit the timeline time range. If I remove clockViewModel here everything is fine. But with that field, every time I change graphData the map reloads. Is there a way I can change graphData, while keeping a custom timeline, without reloading the map?
<Viewer
id="wdt-map-viz-cesium"
clockViewModel={myClock}
<Camera/>
<CameraFlyTo
destination={startCoordinates}
orientation={startOrientation}
duration={0}
graphData && graphArray
graphData.map((rule, index) => (
<Entity
key={rule.apc}
position={Cartesian3.fromDegrees(
rule.location.longitude,
rule.location.latitude,
graphArray[index].offset,
name={rule.apc}
description={`<div>Days to deploy: ${rule.daysToDeploy}</br>`}
box={graphArray[index]}
</Viewer>
