How to use czml-writer java version
Hi,All,
I built out czml-writer java version. Only see a bounch of .class file. How to run it like .net version.
Shawn
The Java version doesn’t have a command line interface at this point. The code is intended to be used as a class library from your own application where you want to generate CZML files programmatically.
