I want to use Offline ArcGIS Maps.
I have written this script:
If I debug and goto Network in Chrome, Seems like it does not load all map tiles, but only 1 tile, which is not found.
Also it gives error for https://www.bingmapsportal.com/ and http://bd.xingcloud.com/ which is done by default.
I have not installed node.js, Is it a must to install it?
Thanks
It sounds like you might be running into this bug:
https://github.com/AnalyticalGraphicsInc/cesium/pull/2481
It will be fixed in Cesium 1.7 to be released March 2, or you can build Cesium yourself from GitHub to get it sooner. Instructions for building it yourself are here:
https://github.com/AnalyticalGraphicsInc/cesium/wiki/Contributor%27s-Guide
Kevin
I have used Cesium.TileMapServiceImageryProvider to use image map files for offline use.
Now I want to have Terrain in my project for offline use. Is it possible to have some Terrain data files ?
Umar
