how to use wms?
Hi everyone,
I try to loade imagery layer from http://geoservices.rijkswaterstaat.nl/vaarwegenkaart_nl
I have seen it with openlayers in http://maps.grade.de/
I want to use this imagery with cesium and I use this code to load it but I got erros such as “An error occurred in “v”: Failed to obtain image tile X: 1 Y: 0 Level: 1.”
var imagery=new Cesium.WebMapServiceImageryProvider({
url: ‘http://geoservices.rijkswaterstaat.nl/vaarwegenkaart_nl’,
layers: ‘vaarwegenkaart_nl’,
parameters: {
TRANSPARENT: true,
SERVICE: ‘WMS’,
VERSION: ‘1.1.1’,
REQUEST: ‘GetMap’,
FORMAT: ‘image/png’,
SRS: ‘EPSG:3857’,
BBOX: ‘313086.0678125,6574807.4240625,626172.135625,6887893.491875’,
WIDTH: ‘256’,
HEIGHT: ‘256’
How can I use this service in cesium?
Regards.
I have also found this wms inside openseamap: http://osm.franken.de:8080/geoserver/wms
I can’t find how to use it in cesium.
Any help will be welcomed.
Regards.
Since you’re requesting tiles in the EPSG:3857 spatial reference system, you need to assign the tiling scheme property to:
tilingScheme: new Cesium.WebMercatorTilingScheme()
You also don’t need the Request, BBOX, or Version parameters, they’ll be added dynamically as the viewport changes.
Hi Denver Pierce,
I have changed my code as you told but it didn’t resolve my issue. Still the same error “failed to obtain image”.
however I request manually this map directly in web browser: http://geoservices.rijkswaterstaat.nl/vaarwegenkaart_nl?request=getmap&service=wms&format=image%2Fpng&layers=vaarwegenkaart_nl&version=1.3.0&crs=EPSG%3A32631&BBOX=-82.8481,-179.603,-7.16055,179.606&width=250&height=250&styles=
Is there something wrong in my url above and why I can’t have image like this below. As an information, this url is obtained by reading according to the getcapability request.
it does not provide the same image that I see in http://maps.grade.de/ Here is what should this map looks like:
You configuration is probably fine. Your working image link does not have a CORS header, which is the reason Cesium can’t access it. I recommend you check out the Imagery Tutorial, which has a section on dealing with CORS. Ideally you would have them enable CORS on the server, but if that’s not an option, going through a Proxy is the only option.
