visualising images on Cesium globe from Geoserver
I am trying to load Bhuvan imagery on to the Cesium globe through Geoserver.
I used WMS layer from bhuvan server and loaded in geoserver. I can visualise the output in geoserver. But while loading the same image on to the Cesium Globe, I am facing the error as :
An error occurred in "p": Failed to obtain image tile X: 1 Y: 0 Level: 0.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 0 Y: 0 Level: 0.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 1 Y: 0 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 1 Y: 1 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 3 Y: 0 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 0 Y: 0 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 2 Y: 0 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 0 Y: 1 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 3 Y: 1 Level: 1.
Cesium.js:477 An error occurred in "p": Failed to obtain image tile X: 2 Y: 1 Level: 1.
<body>
<div id=“cesiumContainer”></div>
    <script>
        var imageryLayers = viewer.imageryLayers;
        imageryLayers.addImageryProvider(new Cesium.WebMapServiceImageryProvider({
            url: ‘http://localhost:8080/geoserver/wms’,
            layers: ‘vector:AP_ERO50K_0506’,
            parameters: {
                transparent: true,
                format: ‘image/png’
    </script>
</body>
I am trying to load imagery layers on Cesium for comparing them and to do Disaster studies.
Cesium : 1.41
OS: Windows 10
Browser: Google chrome
Hi there,
Check the developer console for what errors you are getting that are preventing the tile requests. Most likely this is a CORS issue, you will need to set the proper configuration on your server.
Gabby
