Hi!
I have a kml file that i have loaded with the method loadUrl. This file is well loaded in the viewer but I can’t zoom into it programmatically using the method zoomTo.
Here is my code:
<script>
var dataSource1 = new Cesium.KmlDataSource();
dataSource1.loadUrl(“http://localhost:7299/Scripts/Cesium/datasource/MadaTrek.kml”);
viewer.dataSources.add(dataSource1);
</script>
I have looked within the code ‘gx KML extensions - Bike Ride’ in sandCastle example but I can’t adapt my code to it. I got an error when calling the method
viewer.dataSources.add(Cesium.KmlDataSource.load(‘http://localhost:7299/Scripts/Cesium/datasource/MadaTrek.kml’)).then(function(dataSource){
Any help will be welcomed
Regards.
It looks like you aren’t actually declaring an instance of the viewer object. Assuming you are, can you post a more complete code example. Nothing else jumps out at me as incorrect.
Thanks. this is my code:
<script>
timeline: false,
animation: false,
homeButton: false,
screenModePicker: false,
navigationHelpButton: false,
sceneMode: Cesium.SceneMode.SCENE3D
var cesiumTerrainProviderMeshes = new Cesium.CesiumTerrainProvider({
url: ‘//assets.agi.com/stk-terrain/world’,
requestWaterMask: true,
requestVertexNormals: true
viewer.terrainProvider = cesiumTerrainProviderMeshes;
viewer.zoomTo(dataSource1)
</script>
And when I have adapted my code to ‘gx KML extensions - Bike Ride’ example, I have done like below:
viewer.zoomTo(dataSource);
So I can’t see how to adapt it with the gx kml example.
Regards
Is your page running on the same server as your KML file? Does it work without the zoomTo? This code is perfectly valid and works when I use it with one of my own KML files.
Yes kml file is on the same server as my page.
and yes, this code doesn’t work even without the zommTo
<script>
</script>
I got an error: undefined function on the Cesium.KmlDataSource.load
Regards.
Can you share the KML file?
I solved my problem by using the camera property of the viewer object. This is what I did:
but the zoomTo or flyTo method of a viewer object didn’t still work.
Regards
