Matt,
Here is the sandcastle example.  I tried it at home (safari) and it looks ok.  I'll try it at again at work (firefox) and will let you know.
var scene = viewer.scene;
var canvas = viewer.canvas;
canvas.setAttribute('tabindex', '0'); // needed to put focus on the canvas
canvas.onclick = function() {
    canvas.focus();
var ellipsoid = scene.globe.ellipsoid;
// disable the default event handlers
scene.screenSpaceCameraController.enableRotate = false;
scene.screenSpaceCameraController.enableTranslate = false;
scene.screenSpaceCameraController.enableZoom = false;
scene.screenSpaceCameraController.enableTilt = false;
scene.screenSpaceCameraController.enableLook = false;
var startMousePosition;
var mousePosition;
var flags = {
    looking : false,
    moveForward : false,
    moveBackward : false,
    moveUp : false,
    moveDown : false,
    moveLeft : false,
    moveRight : false,
    pan : false,
    unPan : false
var handler = new Cesium.ScreenSpaceEventHandler(canvas);
handler.setInputAction(function(movement) {
    flags.looking = true;
    mousePosition = startMousePosition = Cesium.Cartesian3.clone(movement.position);
}, Cesium.ScreenSpaceEventType.LEFT_DOWN);
    mousePosition = movement.endPosition;
handler.setInputAction(function(position) {
    flags.looking = false;
}, Cesium.ScreenSpaceEventType.LEFT_UP);
function getFlagForKeyCode(keyCode) {
    switch (keyCode) {
    case 'W'.charCodeAt(0):
        return 'moveForward';
    case 'S'.charCodeAt(0):
        return 'moveBackward';
    case 'Q'.charCodeAt(0):
        return 'moveUp';
    case 'E'.charCodeAt(0):
        return 'moveDown';
    case 'D'.charCodeAt(0):
        return 'moveRight';
    case 'A'.charCodeAt(0):
        return 'moveLeft';
    case 'P'.charCodeAt(0):
        return 'pan';
    case 'U'.charCodeAt(0):
        return 'unPan';
    default:
        return undefined;
document.addEventListener('keydown', function(e) {
    var flagName = getFlagForKeyCode(e.keyCode);
    if (typeof flagName !== 'undefined') {
        flags[flagName] = true;
}, false);
document.addEventListener('keyup', function(e) {
        flags[flagName] = false;
}, false);
viewer.clock.onTick.addEventListener(function(clock) {
    var camera = viewer.camera;
    if (flags.looking) {
        var width = canvas.clientWidth;
        var height = canvas.clientHeight;
        // Coordinate (0.0, 0.0) will be where the mouse was clicked.
        var x = (mousePosition.x - startMousePosition.x) / width;
        var y = -(mousePosition.y - startMousePosition.y) / height;
        var lookFactor = 0.05;
        camera.lookRight(x * lookFactor);
        camera.lookUp(y * lookFactor);
    // Change movement speed based on the distance of the camera to the surface of the ellipsoid.
    var cameraHeight = ellipsoid.cartesianToCartographic(camera.position).height;
    var moveRate = cameraHeight / 100.0;
    if (flags.moveForward) {
        camera.moveForward(moveRate);
    if (flags.moveBackward) {
        camera.moveBackward(moveRate);
    if (flags.moveUp) {
        camera.moveUp(moveRate);
    if (flags.moveDown) {
        camera.moveDown(moveRate);
    if (flags.moveLeft) {
        camera.moveLeft(moveRate);
    if (flags.moveRight) {
        camera.moveRight(moveRate);
    if (flags.pan) {
       //console.warn(scene.camera.pitch);
       scene.camera.setView({
           pitch : (scene.camera.pitch + scene.camera.defaultRotateAmount * 5)
    if (flags.unPan) {
            pitch : (scene.camera.pitch - scene.camera.defaultRotateAmount * 5)
