Image material being applied to wall incorrectly?
I’m trying to create a wall where an image is applied along the entire extent. This works when there are two positions defined but not when three or more positions are defined. I couldn’t find any information in the documentation describing how an image is applied to a wall, so I’m not sure if this is a bug or not.
Here’s a Sandcastle example that demonstrates the problem.
var material = new Cesium.ImageMaterialProperty({
image: ‘…/images/Cesium_Logo_overlay.png’,
repeat: new Cesium.Cartesian2(1.0, 1.0)
var wall_1 = viewer.entities.add({
wall: {
positions: Cesium.Cartesian3.fromDegreesArray([
-110.0, 38.0,
-109.0, 38.0]),
maximumHeights: [ 10000.0, 10000.0 ],
minimumHeights: [ 0.0, 0.0 ],
material: material
var wall_2 = viewer.entities.add({
wall: {
-110.0, 39.0,
-109.5, 39.0,
-109.0, 39.0]),
maximumHeights: [ 10000.0, 10000.0, 10000.0 ],
minimumHeights: [ 0.0, 0.0, 0.0 ],
material: material
viewer.zoomTo(wall_2);
Hmm, yeah it looks like the texture coordinates are incorrect.
I’ve created an issue here: https://github.com/AnalyticalGraphicsInc/cesium/issues/2872
It should be an easy fix, I’ll try to take a look at it shortly.
Thanks!
-Hannah
A fix for this was just merged into master: https://github.com/AnalyticalGraphicsInc/cesium/pull/2873
-Hannah
