ImageryLayer API
Hi All,
I try to get the ImageryLayer from centralBody, I always got “undefined”. Is the API changes?
var imageryLayers = viewer.centralBody.imageryLayers;
alert(imageryLayers);
I look at the document and change ‘imageryLayers’ to ‘imageryLayer’, still ‘undefind’.
Then I loop ‘centralBody’ object, I only got ‘_imageryLayerCollection’, there’s no ‘imageryLayer’. So how to get ‘ImageryLyaer(s)’ from ‘centralBody’? Thanks.
The code you posted is correct for b26. In b25 and older versions, the imageryLayers property was a function named getImageryLayers().
