Hi All, I am looking for some advice about using Cesium for an existing 2D project.
I have a web-app called Heatflask (https://heatflask.herokuapp.com) that uses Leaflet.js as the 2D map API. It presents a visualization of movement tracks in what I call a semi-static or a frequency-map.
The semi-static representation is “semi-static” in the sense that we see the whole activity animated at once, with several copies of the moving entity, moving in parallel.
I have been looking for ways that I can do this in 3D and Cesium looks like a good choice.
The thing is that the the CZML examples I’ve seen just won’t cut it. I need to be able to do this for a thousand or more data tracks.
Also, the movement is continuous and periodic, not just a single replay. And it is interactive. I need to be able to select tracks.
Can someone experienced with Cesium give me some idea how I might go about doing this?
Thanks! – Efrem
