Implementing a Cesium globe screenshot functionality
Hi at all,
I'm a GWT SW developer. I'm implementing GWT-Cesium web and I need to implement a screenshot functionality to store it in the server, only including the Cesium area without the rest of GWT components.
thanks a lot
Regards.
Something like this should do the trick:
https://github.com/TerriaJS/terriajs/blob/master/lib/Models/Cesium.js#L368
While Kevin’s code works, there’s no need for it to be asynchronous. You can just manually call render right before toDataURL and everything is fine. Here’s a Sandcastle example that pops up a screenshot in a new window. (You could also simulate a download with a link element if you would rather do that).
Sandcastle.addToolbarButton(‘Snap’, function(){
viewer.render();
window.open(viewer.canvas.toDataURL(“image/png”));
We saw a problem with that approach… on Firefox maybe? It could be an old problem at this point, though. YMMV.
