I am developing an application in which I need to render 3Dtiles according to the position of a vehicle in real time.
I converted the tifs from EPSG:4326 to tifs ESPG:3857 with GDAL wrap, converted the tifs to .obj with blender and blender-gis and checked that the pivot is in the center. With GDAL, I checked the geographic center of each tif and then placed each asset / tile in its respective location. However, as you can see in the image, they are superimposed.
I am using Cesium ION to save the tiles and I tried in different ways to render them:
1st I adjusted the position (lat, lon) in Cesium ION. It did not work.
2nd I did not adjust the location in the ION and defined it in real time from a JSON. It did not work.
3rd I used the center of the first rendered tile as a reference, and calculated the position of the others in relation to this one (adding the width or length to the point respectively). It did not work.
I leave attached a print with a demonstration of the error happening.
I checked and the coordinates given to each tile are 3768.08 m apart, which should be the value to be side by side and not overlap. The error is about 30%.
They are tifs of the bottom of the sea with bathymetry which I converted to .obj in blender. I tried to do the rendering with terrain files instead but because they are underwater (and the vehicle) I was not able to, so I’m using obj instead.
I have the lat/lon coordinates of the center where the obj pivot is supposed to be (It looks like it on cesium ion) and use this to render the tiles. In the example I gave they are meant to be side by side without overlap. I calculated the distances between centers and there should be no overlap.
Once that is fixed your approach should work. In the meantime, I think the only way to do this correctly would be to use the REST API to pass in a longitude, latitude while uploading, so that the model origin is correctly placed there.
Other than that, I am curious to hear why the underwater terrain files didn’t work. Did you try uploading a GeoTIFF version of these to Cesium ion? If so, do you have the asset IDs for that? I can take a look at that - that may be an easier way to get it to work.
