Hola a todos.
Que es lo minimo que debo instalar en un servidor para poder corrercesium incluyendo 3D.
Librerias etc…
Se debe a que estoy utilizando un servidor de pruebas y es limitado en espacio.
Gracias.
Javier.
Hola a todos.
Librerias etc…
Gracias.
Javier.
Hey Javier,
The Hello World example is the simplest Cesium app (check out the getting started tutorial here https://cesiumjs.org/tutorials/cesium-up-and-running/). I believe you’ll need everything in the Build/Cesium folder.
Muchas gracias.
He probado y funciona.
Otra cosa, ¿donde puedo encontrar un gltf que sea un barco de vela?.
Glad that worked!
I’ve found Google’s Poly to be a good place for 3D models. Here are some boats:
https://poly.google.com/search/boat
Most 3D models there can be downloaded as glTF’s I believe. You can also find any 3D model and convert it to glTF, here’s one converter but there are many others as well:
Forgot to add: sounds like you’re building a fun project, be sure to share it on here when it’s done! I’d love to see.
