Im new to using Cesium and have what is hopefully an easy question. I'm trying to interpolate the positions of a polygon over time in CZML.
There is a similar question on the forum, but the given answer doesn't seem to be working for me. I am assuming this is because the post is quite old and changes have been made since then.
Here is the code I have:
"id": "thing",
"availability":"2012-08-04T16:00:00Z/2012-08-04T17:04:54.9962195740191Z",
"polygon": {
"positions": {
"references": [
"v1#position",
"v2#position",
"v3#position"
"material": {
"solidColor": {
"color": {
"rgbaf": [0.0, 1.0, 0.0, 0.5]
"id": "v1",
"position": {
"interpolationAlgorithm": "LAGRANGE",
"interpolationDegrees": 1,
"epoch": "2012-08-04T16:00:00Z",
"cartographicDegrees": [0.0, -117.0, 34.9, 2.0,
3894.0, -117.1, 34.9, 0.5]
The goal would be to have the vertex represented by 'v1' interpolate over the given time span. When I load this however, I receive a RangeError: invalid array length.
Ive noticed that when the cartographicDegrees of 'v1' is an array of 3 elements (aka as a static geometry) there is no problem. So it seems the time from epoch format is not supported for polygons? Is there perhaps a different approach to accomplishing what I'm trying to do?
Thanks
Brad
