Hello!
A very quick question regarding interpolation in CZML file data (well, interpolation in Cesium in general).
When using captured positioning data, if one drives the animation Timer to a moment well before or well after the end of data availability for a given object, the object’s position gets interpolated accordingly and, as expected, goes berserk.
This would not be a problem if all dynamic objects would have the same start and stop moments in the dataset (one would simply limit the viewable timeline) - only they don’t.
Is there a CZML property I can set with the specific interval an interpolation should be applied (or, the other way around, should NOT be applied? anything goes).
Many thanks!
actually, the thought hadn’t crossed my mind.
