I am using SandCastle interpolation example and have successfully interpolated multiple object with different availabilities but once the stop time of any entity passes the object disappears , i want objects to stay at their end point while other approaching their end time. Please help.
This is the way our interval system is meant to work. The only way I know of to keep the object around would be to add an interval that lasts until the end or your clock range.
Hannah
See the forwardExtapolationType options on SampledProperty: https://cesiumjs.org/Cesium/Build/Documentation/SampledProperty.html#forwardExtrapolationType There is also backwardExtrapolationType. In both cases you can also set the duration (i.e. forwardExtrapolationDuration).
It sounds like you want to set the type to HOLD.
Yes actually i used HOLD for keeping the object stay at it end point, but to keep it visible until its start time reaches i had to add an interval , that was quiet difficult though, but that did the job for me. Thanks a lot.
Ammar
Great, thats worked like a charm, actually i was trying to achieve something like this programmatically.
Time : 1--------------2------------3
Object A : *--------------*------------*
Object B : *------------*
So along with keeping the object to HOLD at point 3 i had to keep the object B visible while object A is moving from 1 to 2. So along with adding interval i used HOLD thing to achieve my goal.
Ammar
