This is what I have in cesium/Workers/createVerticesFromQuantizedTerrainMesh.js
Happens only for IOS 14.x
using ‘1.109.0’
using ‘1.109.0’
Is this the same case for 1.108 or 1.110?
And are you loading CesiumJS via a script tag, or building the code?
Gabby
Issue was because of last changes, not only IOS, also for firefox <= 114. So i have moved to 1.108 version and it works now. Building with vite config
Got it. Is this occurring with version 1.110 as well? I may suggest an adjustment to your build config.
If you’d like to troubleshoot to ensure future version are working as well, please provide your config and we can take a look.
hey, thanks. this is our cesium plugin config with vite
import fs from 'fs-extra';
import path from 'path';
import serveStatic from 'serve-static';
import { Plugin, UserConfig } from 'vite';
export default function vitePluginCesium(): Plugin {
let outDir = 'dist';
let isBuild = false;
return {
config(c, { command }) {
isBuild = command === 'build';
if (c.build?.outDir != null) {
outDir = c.build.outDir;
const userConfig: UserConfig = {};
return userConfig;
configureServer({ middlewares }) {
middlewares.use('/cesium/', serveStatic('node_modules/cesium/Build/Cesium'));
async closeBundle() {
if (isBuild) {
const cesiumBuildPath = 'node_modules/cesium/Build/Cesium/';
try {
await fs.copy(path.join(cesiumBuildPath, 'Assets'), path.join(outDir, 'cesium/Assets'));
await fs.copy(path.join(cesiumBuildPath, 'ThirdParty'), path.join(outDir, 'cesium/ThirdParty'));
await fs.copy(path.join(cesiumBuildPath, 'Workers'), path.join(outDir, 'cesium/Workers'));
await fs.copy(path.join(cesiumBuildPath, 'Widgets'), path.join(outDir, 'cesium/Widgets'));
await fs.copy(path.join(cesiumBuildPath, 'Cesium.js'), path.join(outDir, 'cesium/Cesium.js'));
} catch (err) {
console.error('copy failed', err);
So now cesium version is 1.108.0, but the issue is with iPhone 11 and IOS 14.
