I created a simple vue + vite app then installed cesium. However, importing cesium is causing my project to be unable to run without errorring out. I am running on Ubuntu 22.04
To recreate, I created a new project using
yarn create vite my-vue-app --template vue
cd my-vue-app
yarn add cesium vite-plugin-cesium vite -D
Then updated the vite config to utilize vite-plugin-cesium:
// vite.config.js
import { defineConfig } from 'vite'
import vue from '@vitejs/plugin-vue'
import cesium from 'vite-plugin-cesium'
import path from 'path'
// https://vitejs.dev/config/
export default defineConfig({
plugins: [vue(), cesium()],
resolve: {
alias: {
'@': path.resolve(__dirname, './src')
In HelloWorld.vue, I imported cesium using either import * as Cesium from 'cesium' or import { Viewer } from 'cesium'.
Then running yarn dev give me the error:
✘ [ERROR] Failed to resolve entry for package "https". The package may have incorrect main/module/exports specified in its package.json. [plugin vite:dep-pre-bundle]
node_modules/esbuild/lib/main.js:1373:21:
1373 │ let result = await callback({
at packageEntryFailure (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:28725:11)
at resolvePackageEntry (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:28722:5)
at tryNodeResolve (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:28453:20)
at Context.resolveId (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:28212:28)
at Object.resolveId (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:44276:64)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:65922:21
at async file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:39976:34
at async requestCallbacks.on-resolve (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:1373:22)
at async handleRequest (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:729:13)
This error came from the "onResolve" callback registered here:
node_modules/esbuild/lib/main.js:1292:20:
1292 │ let promise = setup({
at setup (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:39956:19)
at handlePlugins (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:1292:21)
at buildOrContextImpl (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:978:5)
at Object.buildOrContext (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:786:5)
at /home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:2186:68
at new Promise (<anonymous>)
at Object.context (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:2186:27)
at Object.context (/home/andrea/projects/test/my-vue-app/node_modules/esbuild/lib/main.js:2026:58)
at prepareEsbuildOptimizerRun (file:///home/andrea/projects/test/my-vue-app/node_modules/vite/dist/node/chunks/dep-bb8a8339.js:46041:35)
The plugin "vite:dep-pre-bundle" was triggered by this import
node_modules/@cesium/engine/Source/Core/Resource.js:2076:48:
2076 │ return URL.protocol === "https:" ? import("https") : import("http");
Any ideas of what the issue is that is causing this error would be appreciated. Thank you
