Hey,
I’m trying to pack the cesium+react+typescript+vite+resium project (Let’s call it project A) and use it as a package (npm) in project B ($~proj/B npm i A).
In project B I’ve got the following error: “Uncaught ReferenceError: Cesium is not defined at @B”.
Here are the configuration files of Project A:
vite.config.ts
/// <reference types="vite/client" />
import { resolve } from 'path';
import { defineConfig } from 'vite';
import react from '@vitejs/plugin-react-swc';
import cesium from 'vite-plugin-cesium';
// import dts from "vite-plugin-dts";
// import typescript from '@rollup/plugin-typescript';
// https://vitejs.dev/config/
export default defineConfig({
plugins: [
react(),
cesium(),
// typescript(),
// dts({
// rollupTypes: true,
// exclude: ["./src/env.d.ts"],
build: {
lib: {
formats: ['es', 'umd'],
entry: resolve(__dirname, 'src/index.tsx'),
fileName: (format) => `index.${format}.js`,
rollupOptions: {
external: ["cesium", "react", "react-dom"],
output: {
globals: {
cesium: "Cesium",
react: "React",
"react-dom": "ReactDOM",
tsconfig.json
"compilerOptions": {
"target": "es5",
"lib": [
"dom",
"dom.iterable",
"esnext"
"rootDir": "src",
"sourceMap": true,
"outDir": "./dist",
"declaration": true,
"noImplicitReturns": false,
"noFallthroughCasesInSwitch": false,
"noUnusedLocals": false,
"noUnusedParameters": false,
"downlevelIteration": true,
"allowJs": true,
"skipLibCheck": true,
"esModuleInterop": true,
"allowSyntheticDefaultImports": true,
"strict": true,
"forceConsistentCasingInFileNames": true,
"module": "esnext",
"moduleResolution": "node",
"resolveJsonModule": true,
"isolatedModules": true,
"noEmit": true,
"jsx": "react-jsx"
"ts-node": {
"module": "CommonJS"
"include": [
"src"
tsconfig.node.json
"composite": true,
"module": "ESNext",
"moduleResolution": "bundler",
"include": ["vite.config.ts"]
package.json
"name": "@proj/A",
"version": "0.1.0",
"private": true,
"type": "module",
"main": "./dist/index.umd.js",
"module": "./dist/index.es.js",
"types": "./dist/index.d.ts",
"exports": {
"import": "./dist/index.es.js",
"require": "./dist/index.umd.js"
"files": [
"dist/",
"src/",
"!src/**/*.test.ts"
"scripts": {
"dev": "vite --port 3000",
"build": "tsc && vite build",
"lint": "eslint . --ext ts,tsx --report-unused-disable-directives --max-warnings 0",
"preview": "vite preview --port 3000"
"dependencies": {
"cesium": "^1.106.1",
"react": "^18.2.0",
"react-dom": "^18.2.0",
"resium": "^1.16.1"
"devDependencies": {
"@babel/plugin-proposal-private-property-in-object": "^7.21.11",
"@rollup/plugin-typescript": "^11.1.5",
"@testing-library/jest-dom": "^6.1.2",
"@testing-library/react": "^14.0.0",
"@testing-library/user-event": "^14.4.3",
"@types/jest": "^29.5.4"
"@types/react": "^18.2.12",
"@types/react-dom": "^18.2.5"
"@typescript-eslint/eslint-plugin": "^6.14.0",
"@typescript-eslint/parser": "^6.14.0",
"@vitejs/plugin-react-swc": "^3.5.0",
"eslint": "^8.55.0",
"eslint-plugin-react-hooks": "^4.6.0",
"eslint-plugin-react-refresh": "^0.4.5",
"tslib": "^2.6.2",
"typescript": "^4.9.5",
"vite": "^5.0.8",
"vite-plugin-cesium": "^1.2.22",
"vite-plugin-dts": "^3.6.4"
"eslintConfig": {
"extends": [
"react-app",
"react-app/jest"
"browserslist": {
"production": [
">0.2%",
"not dead",
"not op_mini all"
"development": [
"last 1 chrome version",
"last 1 firefox version",
"last 1 safari version"
The main.tsx of Project B:
import React from 'react'
import ReactDOM from 'react-dom/client'
import { MapStateProvider, MapViewer } from '@proj/A';
import './index.css'
ReactDOM.createRoot(document.getElementById('root')!).render(
<React.StrictMode>
<MapStateProvider><MapViewer style={{ height: "80vh"}}></MapViewer></MapStateProvider>
</React.StrictMode>,
