Is ClampToGround not supported for Billboards in CZML?
Attempting to add “heightReference” : Cesium.HeightReference.CLAMP_TO_GROUND, to Billboard options in CZML,
TypeError: Cannot read property ‘length’ of undefined
the full error is
at processProperty (Cesium.js:137465)
at processPacketData (Cesium.js:137603)
at Array.processBillboard (Cesium.js:138107)
at processCzmlPacket (Cesium.js:138685)
at Function.CzmlDataSource._processCzml (Cesium.js:139063)
at loadCzml (Cesium.js:138797)
at Cesium.js:138778
at Promise.then (Cesium.js:1163)
at when (Cesium.js:1026)
at load (Cesium.js:138777)
insert on Line #11: “heightReference” : Cesium.HeightReference.CLAMP_TO_GROUND,
I am trying to animate a GPX tracklog using Billboard entities to represent the '“breadcrumb trail”. A better way night have been to include native support for GPX files in Cesium, if that project by Andre Nunes had ever been merged into master… then I wouldn’t struggle writing code to generate a CzmlDataSource from the GPX XML, which works great until I attempt to ClampToGround.
Cesium v1.4.8, Windows 7, Chrome
(NOT “heightReference”, which is usually the proper syntax)
However, the billboard still disappears underground at certain times&places when the GPS Z elevation value is less than the Z value of Cesium World Terrain.
Which leads me back to the original question,
The AGI logo graphic disappears underground in
when you paste the following line #11
“HeightReference”: Cesium.HeightReference.CLAMP_TO_GROUND,
change to Cesium World Terrain in the Basemap Picker and zoom in on the AGI logo.
Thanks-
-Jon
I solved the “TypeError: Cannot read property ‘length’ of undefined”, after reading https://github.com/AnalyticalGraphicsInc/cesium/blob/1.48/Source/DataSources/CzmlDataSource.js and realizing that in a CZML document, I need to capitalize “HeightReference”: Cesium.HeightReference.CLAMP_TO_GROUND,
The correct syntax in CZML is:
“heightReference”: “CLAMP_TO_GROUND”
sandcastle example
The CZML property names for billboards are listed here:
https://github.com/AnalyticalGraphicsInc/czml-writer/wiki/Billboard
and the string values for the HeightReference type are listed here:
https://github.com/AnalyticalGraphicsInc/czml-writer/wiki/HeightReferenceValue
Thank you, Scott!
