I have tried attaching to loadingEvent, but that doesn’t work.
I can roll my own thing by writing more code when I change the show state myself, but I was hoping there was a built-in event that would fire an event when the value of show changed.
If there is not, perhaps it would be appropriate for a changed event to fire?
I found an answer that works, but I don’t like it.
An Entity will emit a definitionChanged event when the show state of the entity changes.
What I did is add a listener for the definitionChanged event to one of the entities in the CustomDataSource. When this listener is executed, I can make the assumption that the show state of the datasource has changed.
However, this feels like a hack rather than the way it is supposed to work.
I looks like it would be straightforward to do something similar for the CustomDataSource and create a new showStateChanged event for it to emit when the state changes.
If such a pull request would be accepted, I may be able to find the time to create one and get this feature in there. Would it?
It would make sense to implement a definitionChanged event for CustomDataSource, but that PR would be to large a task for me to take on at this time.
I guess this is a design issue rather than an implementation issue, CustomDataSource is just a manager, and when designing this API it may not be needed to manage too many events, which would make things confusing and complicated.
