I have succeeded in obtaining a tile of a certain level and obtaining the x, y number of that tile.
let tileLevels = [];
let tiles = [];
this.viewer.scene.globe._surface.forEachRenderedTile((tile) => {
tileLevels.push(tile.level);
if(tile.level>14){
tiles.push(toString(tile.x),',',toString(tile.y));
console.log(`test | ${tile.level}, ${tile.x}, ${tile.y}`);
// tile.rectangle are available
console.log(`test | levels : (${tileLevels.length}) [${tileLevels}]`);
var ntile = Math.min.apply(null, tileLevels);
I plan to place characteristic symbol objects on the tiles with the smallest level, and gradually deepen building objects from the highest level tiles (exceeding level 14 in the code), which are the core.
The type of data you have is an index value that has nothing to do with a specific geographic range, making it difficult to infer latitude and longitude from an index.
I want to call the corresponding index in batch based on the tile information captured in the view.
Can I get the vertex of each tile? I want to get latitude and longitude through it.
