Is there some tools to compress the b3dm file like the dragon version of gltf
I have some b3dm files generated by smart3D(contextcapture), there are several tileset in different folders, is there some ways to compress them by batching process.
You can compress the files with Draco compression using the 2.0 branch of gltf-pipeline, or you could gzip the file.
Gabby
