We have a GLTF model with triangle and line primitives. When we compress using Draco from gltf-pipeline:2.0, the filesize increases a bit from the original. If we remove the line primitives from GLTF, draco compression works fine and file becomes 10 times smaller.
Is it possible to use Draco compression for other primitives than triangle-meshes?
At least currently, Cesium and gltf-pipeline only decode Draco encoded model mesh geometry, so Models and b3dm tilesets. Correct me if I’m wrong, but I don’t believe [glTF 2.0 supports line primitives](http://We’re working on Point Cloud support currently. ).
Outside of Draco with glTF, we’re working on Draco encoded point cloud support currently, and theoretically it would be a good addition to something like 3D Tiles vector tiles which are intended for geometry like polylines.
Anways, the Draco compression does not work well with lines. Also, what we have notices is that i3dm files, the instanced tiles, do not work with Draco-compressed GLTF in them.
I re-opened #6673 so make sure we get to the bottom of the rotation issue. jsal11, if you can provide sample data that shows the issue that would be great.
I investigated this more and it looks like all our instanced objects are now 90 degrees rotated on z-axis (height direction)… And I also tested that this does -not- have anything to do with Draco compression, at this moment this same 90 degrees offset is there even without this #6673
PR merge. So this might be a false alarm… We will investigate more and let you know.
Cesium uses a X forward convention while glTF 2.0 uses Z forward, and that PR applies a correction. But perhaps this rotation should not be applied to i3dm tiles which provide their own rotation.
The algorithm uses face connectivity to optimization compression. I guess lines could be possible but it is a less common use case. This might be a good question to bring up to the Draco team: https://github.com/google/draco.
