I have tried representing regionally gridded precipitation data as a PointCloud in .pnts format both coloring it using RGB values and by using a Batch Table with no RGB and then trying to style off the Batch Table property.
The points display, but they do not accept any of the 3DTileStyle modifiers that I apply to them.
For version with RGB values and no Batch Table (IMERGtest.pnts):
viewer = new Cesium.Viewer(‘cesiumContainer’,{
geocoder: false,
homeButton: false,
baseLayerPicker: false,
animation: false,
sceneModePicker: false,
imageryProvider: new Cesium.ArcGisMapServerImageryProvider({
url: “https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/”,
enablePickFeatures: false
tilesets = ;
for (var q=0;q<144;q++) {
tilesets.push(viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url: ‘…/include/imergPnts/’+q+’/’,
shadows: Cesium.ShadowMode.DISABLED,
style: new Cesium.Cesium3DTileStyle({
/color: {
conditions: [
[’{precRate} >= 20','color("red")'],
['{precRate} >= 10’,‘color(“green”)’],
[‘true’,‘color(“blue”)’]
pointSize: 1.0,
scaleByDistance: ‘vec4(1e5,5.0,1.2e7,0.3)’
For version without RGB values and with BatchTable (IMERGtestBT.pnts), just remove the comments surrounding the “color” field.
Testing out using Point Clouds to visualize gridded data more efficiently than PointPrimitives
Cesium 1.42; Centos 6; Firefox 52.6.0
IMERGtest.pnts (829 KB)
IMERGtestBR.pnts (884 KB)
tileset.json (185 Bytes)
