Hello, everyone!
I’m currently working on a project in CesiumJS to visualize a point cloud (LAZ format) that includes floor information stored in the UserData field. My goal is to color the points based on the floor level. The point cloud itself displays correctly, but I am facing difficulties when trying to use the UserData field to color the points.
To provide some context:
- LAZ File Generation:
I generated the LAZ file using PDAL with a pipeline that includes the floor information as UserData. Here’s a simplified version of the PDAL pipeline I used:
"pipeline": [
"type": "readers.text",
"filename": "temp_csv_path",
"separator": ",",
"skip": 1,
"header": "X,Y,Z,GpsTime,PointId,UserData"
"type": "filters.reprojection",
"in_srs": "EPSG:4326",
"out_srs": "EPSG:4326"
"type": "writers.las",
"filename": "output_laz",
"compression": "laszip",
"minor_version": 2,
"dataformat_id": 1,
"filesource_id": 0,
"global_encoding": 0,
"system_id": "PDAL",
"a_srs": "EPSG:4326",
"scale_x": 0.0000001,
"scale_y": 0.0000001,
"scale_z": 0.01,
"offset_x": "auto",
"offset_y": "auto",
"offset_z": "auto"
In this pipeline, the ‘UserData’ column from the input CSV is directly mapped to the UserData field in the LAZ file. The pipeline also includes reprojection to ensure the coordinate system is correctly set to EPSG:4326.
Previous Working Code with Classification:
Previously, I used the Classification field instead of UserData, and it worked correctly. Here’s a snippet of the working code:const floorColorStyle = new Cesium.Cesium3DTileStyle({ color: { conditions: [ ['${Classification} === 0', 'color("blue")'], ['${Classification} === 1', 'color("green")'], ['${Classification} === 2', 'color("red")'], // ... more conditions ['true', 'color("gray")'] ] } }); tileset.style = floorColorStyle;
Current Setup:
I’m using Cesium version 1.118.
The LAZ file was converted to 3D Tiles using Cesium ion.
The tileset is loaded into the scene using the following code:
const tileset = await Cesium.Cesium3DTileset.fromIonAssetId(YOUR_ASSET_ID); viewer.scene.primitives.add(tileset);
Now, with the switch to UserData, I’m encountering issues. Initially, I tried accessing UserData through the getProperty() method, but I encountered the following error:
Uncaught TypeError: Cannot read properties of undefined (reading 'getProperty')
I inspected the picked object’s structure, and it appears to be different from what I expected for 3D Tileset properties. Here’s what the picked object looks like:
Picked feature type: {content: ys, primitive: jo, detail: {…}, id: undefined}
I also tried accessing the batchTable property from the primitive.content, but couldn’t retrieve UserData. Below is a simplified version of the code I am using:
viewer.screenSpaceEventHandler.setInputAction(function (movement) {
const pickedObject = viewer.scene.pick(movement.position);
if (Cesium.defined(pickedObject)) {
const primitive = pickedObject.primitive;
if (primitive && primitive instanceof Cesium.Cesium3DTileset) {
const content = primitive.content;
if (content && content.batchTable) {
const userData = content.batchTable.getProperty(pickedObject.batchId, 'UserData');
console.log('UserData:', userData);
} else {
console.log("Property not found");
Additionally, I am trying to apply a Cesium3DTileStyle to color the points based on the floor information in the UserData field. Here’s the code for the styling:
const floorColors = [
'rgb(0, 0, 128)', // Basement -2
'rgb(0, 0, 255)', // Basement -1
'rgb(0, 128, 255)', // Ground Floor
// ...additional colors for higher floors
'rgb(128, 0, 0)' // 40th Floor
color: {
conditions: floorColors.map((color, index) =>
[`\${UserData} === ${index}`, `color("${color}")`]
).concat([["true", "color('gray')"]]) // Default color
pointSize: 3,
pointOutlineColor: "color('white', 0.3)"
Despite this setup, I’m not seeing the points colored according to UserData. When using Classification for this purpose previously, everything worked fine, but now the transition to UserData seems to have caused an issue.
Any insights on how to correctly access and use the UserData field for styling, or if there’s an issue with how I’m retrieving properties via pickedFeature.getProperty()? Your help would be greatly appreciated!
Thank you in advance!
