I’m trying to make a small “overview” globe using the transparent background technique that’s been discussed here previously. It works well enough but has ugly jagged edges. It seems like anti-aliasing doesn’t work in conjunction with background transparency.
The jagged edges are especially visible on a lower-resolution device.
I have a mapping project built on Cesium and want to offer an “overview globe” – an optional second Viewer in the corner that provides an indicator of where on Earth the main viewer is currently looking. I do this by disabling mouse control of the overview globe, and hooking camera movement on the main viewer to reposition the overview.
I think maybe I need some kind of post-processing on the globe to soften the edges? I tried turning on atmosphere but that just gives the atmosphere rough edges instead. I think the outermost globe pixels need to somehow have a bit of transparency too?
1.55 / latest; this has been the case with every OS / browser combination I’ve tried it from.
