What I hope to achieve is to make the canvas tag of Cesium completely transparent, displaying only the objects that are drawn. The background of the canvas should also be transparent. However, the code I am using does not work
Cesium Simple Geometry @import url("https://cesium.com/downloads/cesiumjs/releases/1.88/Build/Cesium/Widgets/widgets.css"); html, body, #cesiumContainer { width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden; }
    canvas {
        background: transparent !important;
    body {
        margin: 0;
        padding: 0;
        overflow: hidden;
    #cesiumContainer {
        width: 800px;
        /* 定义你想要的宽度 */
        height: 600px;
        /* 定义你想要的高度 */
        position: absolute;
        top: 50%;
        left: 50%;
        transform: translate(-50%, -50%);
        background: transparent;
    #cesiumContainer canvas {
        width: 100% !important;
        height: 100% !important;
        position: absolute;
        top: 0;
        left: 0;
    body {
        background-color: #4d7554;
</style>
<div id="cesiumContainer"></div>
<script>
    // var canvas = document.getElementById('cesiumContainer');
    // var context = canvas.getContext('webgl', { alpha: true });
    // Create the Cesium Viewer without terrain and base imagery
        imageryProvider: false, // Disable default imagery
        baseLayerPicker: false, // Hide the base layer picker
        terrainProvider: false, // Disable terrain
        geocoder: false, // Disable geocoder
        homeButton: false, // Disable home button
        sceneModePicker: false, // Disable scene mode picker
        navigationHelpButton: false, // Disable navigation help button
        animation: false, // Disable animation widget
        timeline: false, // Disable timeline widget
        skyBox: false, // Disable skyBox
        skyAtmosphere: false,// Disable skyAtmosphere
        scene3DOnly: true,
        shadows: false,
        // context: context,
    viewer.scene.backgroundColor = new Cesium.Color(0, 0, 0, 0);
    // viewer.scene.backgroundColor = new Cesium.Color(0, 0, 0, 0.5);
    // viewer.scene.backgroundColor = new Cesium.Color(255, 255,255, 0);
    viewer.scene.globe.baseColor =  Cesium.Color.TRANSPARENT;
    // var canvas = document.querySelector('canvas');
    // Add a simple box geometry
    var boxEntity = viewer.entities.add({
        // Specify longitude, latitude, and altitude
        position: Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883, 0),
        box: {
            dimensions: new Cesium.Cartesian3(400000.0, 300000.0, 500000.0),
            material: Cesium.Color.RED.withAlpha(0.5),
            outline: true,
            outlineColor: Cesium.Color.BLACK
    // Fly to the box
    viewer.camera.flyTo({
        destination: Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883, 1000000.0)
</script>
You should be able to make the canvas transparent by setting the background color to transparent. Here’s a sandcastle showing that off: transparent background. Is this the effect you’re trying to achieve?
Just note you may see an extra black band around the earth with this method if you don’t turn the atmosphere off as shown in this issue
