KML - access polygon
After loading KML using KmlDataSource then looping round the entities there is no polygon. The name and id is accessible ok.
kmlOverlay1.load(‘test.kml’, options).then(function () {
var entities = kmlOverlay1.entities.values;
for (var i = 0; i < entities.length; i++)
var entity = entities[i];
console.log (i + " " + entity.name);
entity.polygon.material = Cesium.Color.WHITE;
Change the color of the polygons.
1.55
Converting the kml file to geojson works, we need to support loading of kml files.
Are you saying the for loop causes the polygons to disappear? But they appear normally without it?
Do you get any console errors? Are you able to produce a Sandcastle example (https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/) of this issue I can look at?
