Is there other way to load the kml file on cesium globe because my kml file is not loading on the globe i have included my .html code
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1"> <!-- Use Chrome Frame in IE -->
<meta name="viewport" content="width=device-width, height=device-height, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<meta name="description" content="Use the Viewer Widget to start building new applications or easily embed Cesium into existing applications.">
<meta name="cesium-sandcastle-labels" content="Beginner, Showcases">
<title>Cesium Demo</title>
<script type="text/javascript" src="../Sandcastle-header.js"></script>
<script type="text/javascript" src="../../../ThirdParty/requirejs-2.1.9/KmlDataSource.js"></script>
<script type="text/javascript" src="../../../ThirdParty/requirejs-2.1.9/Cesium.js"></script>
<script type="text/javascript">
require.config({
baseUrl : '../../../Source',
waitSeconds : 60
</script>
</head>
<body class="sandcastle-loading" data-sandcastle-bucket="bucket-requirejs.html" data-sandcastle-title="Cesium KML">
<style>
@import url(../templates/bucket.css);
</style>
<div id="cesiumContainer" class="fullSize"></div>
<div id="loadingOverlay"><h1>Loading...</h1></div>
<script id="cesium_sandcastle_script">
var builtInKml = 'MY KML FILE';
function useBuiltInKml() {
viewer.extend(Cesium.viewerDynamicObjectMixin);
alert("222");
var kmlDataSource = new Cesium.KmlDataSource();
kmlDataSource.loadUrl(builtInKml, 'Built-in KML');
viewer.dataSources.add(kmlDataSource);
Sandcastle.finishedLoading();
// Zoom in a little closer...
//Give the coordinates of your bounding box
var west = Cesium.Math.toRadians(28.5263327654348);
var south = Cesium.Math.toRadians(77.38484280605337);
var east = Cesium.Math.toRadians(28.53339715213986);
var north = Cesium.Math.toRadians(77.39361675250349);
var extent = new Cesium.Extent(west, south, east, north);
viewer.scene.camera.viewExtent(extent);
useBuiltInKml()
</script>
</body>
</html>
Thanks
Vaibhav
I was going through the code and i found that check2 alert was not working which means there is a problem in line ( var kmlDataSource = new Cesium.KmlDataSource()![:wink: :wink:](https://emoji.discourse-cdn.com/twitter/wink.png?v=9)
Code:
alert(“check1”);
alert(“check2”);
Regards,
vaibhav
KML support is not part of the released version yet. It’s being developed in the kml branch: https://github.com/AnalyticalGraphicsInc/cesium/tree/kml so you’ll have to clone from GitHub and build Cesium yourself.
Hi Scott,
Thanks for the Link. After building Cesium from the link i copied the Cesium.js and KmlDataSource.js in a separate folder and than ran the file but no change in output occurred.
Code:
alert(“check1”);
alert(“check2”);
Regards,
vaibhav
I took clone of kml branch from GitHub : (https://github.com/AnalyticalGraphicsInc/cesium/tree/kml)and builded Cesium now facing problem adding kmldatasources in the viewer.
kmlDataSource.loadUrl('C:/xampp/htdocs/kmlcesium/Apps/Temp.kml').then(function(){
alert("555");
alert("666");
viewer.homeButton.viewModel.command();
alert("777")
It alerts till 555 . I am unable to understand whats the problem in viewer.dataSources.add(kmlDataSource);
If needed i will upload my full code and KML file.
Regards,
vaibhav
Browsers cannot load data from file URLs like: ‘C:/xampp/htdocs/kmlcesium/Apps/Temp.kml’. You must host the KML file on an HTTP server.
I hosted my kml, as ‘http://localhost/kmlcesium/KMLOutputSimple.kml’. I build-ed the kml branch downloaded from github and tried to test cesium.js by running simple helloworld.html i figured out that it was not working that means cesium.js is not building properly.
regards,
vaibhav
I then downloaded already build folder of cesium-b27 and tested the same helloworld.html(from kml branch) by putting it in cesium-b27 folder and there it ran successfully . Am i thinking correct that cesium.js which i am using in kml branch is correct.
I will also like to mention that while manually building kml branch it builded absolutely error free, and after that i used the cesium.js
regards,
vaibhav
This is the error
1.Error: Script file not found: http://localhost:81/cesium-kml/Build/Cesium/Workers/transferTypedArrayTest.js
2.Error: Script file not found: http://localhost:81/cesium-kml/Build/Cesium/Workers/cesiumWorkerBootstrapper.js
) which i am getting after running helloworld.html example of kml branch. I went through the build file and i found this part of code in build.xml.
<exclude name="cesiumWorkerBootstrapper.js" /> <exclude name="transferTypedArrayTest.js" /> <exclude name="createTaskProcessorWorker.js" />
why these js need to be excluded and if they are excluded than why the error for these js files is coming.
Regards,
vaibhav
