KML Loading return error but no information
Using angular-cesium and cesium. ( but this part concern cesium)
I am trying to load a KML model from the internet. I have a server that host the file, and using a request I get the file in draw it into Cesium.
I am doing the same procedure on GLTF and it works fine, but KML fail.
So I load the file and then pass the text result to this function :
loadKML(kml: any) {
console.log(kml)
const loader = Cesium.KmlDataSource.load(Cesium.KmlDataSource.load(kml));
const logId = this.mapLogService.add({log: 'MAP.LOADING.KML'});
Cesium.when(loader).then((lKML) => {
  this.ngZone.run(() => {
    console.log('LOADED')
    this.viewer.dataSources.add(lKML);
    this.mapLogService.remove(logId);
}).otherwise((error) => {
    console.log('FAILED')
    console.log(error)
The result in the logs is the following (attachkement) : https://prnt.sc/pu102o
But since the error are empty, I have no idea what is going wrong.
Any tips ?
If you check the network tab, does the browser show that the KML text has been successfully retrieved?
Are you able to share a sample of this KML file that’s causing this issue? One easy way to test it is to drag and drop it into the Cesium viewer app:
https://cesium.com/downloads/cesiumjs/releases/1.63/Apps/CesiumViewer/index.html
Does that produce a similar error?
Thanks for the reply, yes, it show the KML correctly in the browser response and I try to drag and drop it into the viewer and it does work.
The problem must be in my code then, I will investigate it thanks.
I think the problem is the way I load my KML into cesium,
I already have loaded the KML from my external service, so I have access to the content of the file already in my code. (like if I console.log(myKml) I can see the kml content).
so I need a way to add this content directly to cesium, without asking cesium to reload it.
If you’re passing in your KML content as a string, CesiumJS will interpret it as a URL and try to load it. I think you need to pass a parsed document, so it would look something like this:
var kmlContent = ‘…your kml as text…’;
var parser = new DOMParser();
var kmlDoc = parser.parseFromString(kmlContent, “text/xml”);
viewer.dataSources.add(Cesium.KmlDataSource.load(kmlDoc, options));
Here’s a Sandcastle I just put together showing this.
Sorry, Sandcastle is too long to share because it embeds the whole KML. Here’s the code without the KML itself embedded:
var options = {
camera : viewer.scene.camera,
canvas : viewer.scene.canvas,
sourceUri: ‘https://sandcastle.cesium.com/SampleData/kml/facilities/’
var kmlContent = ‘’;
// Loading KML directly from already loaded content
// Loading it in the usual way
//viewer.dataSources.add(Cesium.KmlDataSource.load(’…/…/SampleData/kml/facilities/facilities.kml’, options));
Thanks you as always for your support.
I will try this tomorrow and keep this post updated.
Thank you,
loadKML(kml: any) {
const parser = new DOMParser();
const kmlDoc = parser.parseFromString(kml, 'text/xml');
const loader = Cesium.KmlDataSource.load(kmlDoc);
Worked perfectly
I’ve tried this strategy, but it doesn’t seem to load .kmz files, likely because the DOMParser can’t parse them. Do you have a solution for that case?
Thanks!
