KML not parsing - Invalid array buffer length
Hi
My KML is not working.
File size is 7 MB
ERROR
undefined
RangeError: Invalid array buffer length
    at new ArrayBuffer (native)
    at new Uint32Array (native)
    at Object.i.createTypedArray (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createGeometry.js:75:16650)
    at F (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createGeometry.js:76:1225)
    at Object.tt.combineInstances (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createGeometry.js:76:15748)
    at Function.H.createGeometry (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createPolygonGeometry.js:230:22544)
    at n (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createPolygonGeometry.js:230:23395)
    at a (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createGeometry.js:77:5951)
    at DedicatedWorkerGlobalScope.n (http://localhost/projects/Cesium-1.14/Build/Cesium/Workers/createGeometry.js:77:5167)
Code -
viewer.dataSources.add(Cesium.KmlDataSource.load('SampleData/DLH/Melco_map_test.kml'))
.otherwise(function(e){
    console.log(e);
    alert(e);
Can you share the file?
URL for KML - http://javascript.solutions/mobile/abc.kml
Same file is working fine with Google earth.
Can anyone see this issue, KML not parsing and showing Invalid array buffer length error ?
Sorry for the delay. It looks like the KML parses and loads into the DataSource correctly but eventually runs out of memory while trying to triangulate the many polygons it contains. I’ve submitted a new bug so that we can look into it: https://github.com/AnalyticalGraphicsInc/cesium/issues/3067
When this issue will be fixed ?
My Project is kind of stuck right now.
thanks for help
